Wobbling Wonder: A Deep Dive into Handling Issues After Tire Replacement on a Fo
Wobbling Wonder: A Deep Dive into Handling Issues After Tire Replacement on a Ford Transit
Replacing tires should be a routine upgrade, not a source of dread. However, @vanlifecrisis’s experience highlights a common problem: new tires, even of the same size and load rating, can sometimes drastically alter a vehicle’s handling characteristics. Let’s dissect the possible causes behind the “sway” and tracking issues plaguing this 2020 Ford Transit F350.
The Symptoms:
  • Sway and Poor Tracking: The most prominent complaint is increased sway and difficulty maintaining a straight line at highway speeds. The van drifts side-to-side by a foot or more.
  • Wind Sensitivity: The issue is exacerbated by wind, suggesting a possible interaction between the vehicle’s inherent top-heaviness and the tires’ response to crosswinds.
  • Tire Pressure Fluctuations: Significant pressure increases were observed during the initial road trip, indicating heat buildup within the tires.
  • Limited Success with Tire Pressure Adjustments: Increasing the front tire pressure to 70 psi did not yield a significant improvement.
Possible Causes, Ranked by Probability and Impact:
  1. Tire Construction and Compound Differences:
    • The Culprit: This is the most likely primary cause. While the Michelin Agilis Crossclimate DT tires are the same size as the original tires, their internal construction, rubber compound, and tread pattern are undoubtedly different. These differences significantly impact handling characteristics.
    • Why it Matters: The original tires likely had a different carcass construction. Stiffer sidewalls provide more lateral stability and resistance to flexing, reducing sway. The Agilis Crossclimate DT, being an “all weather” tire, might prioritize snow and ice traction over dry pavement stability, resulting in a softer sidewall and more flexibility. Even the tread pattern, while appearing similar, can have a big impact. A pattern designed for grip in snow might have more “give” on dry pavement, leading to a feeling of sway.
    • Michelin’s Position (Hypothetical): Michelin might argue that the Agilis Crossclimate DT is designed for a broad range of conditions and that the reported handling is within acceptable parameters for the target user (commercial vans needing all-weather capability). Their focus is likely on safety, longevity, and winter performance.
    • Example: Imagine comparing a high-performance summer tire with a dedicated winter tire on dry pavement. The summer tire will feel much more precise and responsive, while the winter tire will feel squirmy and less stable. The difference comes down to compromises in design.
  2. Tire Pressure - Still a Contender:
    • The Nuance: While @vanlifecrisis followed the door sticker recommendation (57 front/80 rear), and even tried 70 in the front, optimal tire pressure isn’t always a static number. It can vary based on actual load, road conditions, and even individual preference.
    • The Issue: Significant pressure increases during the road trip indicate the tires are working hard and generating heat. Under-inflation (relative to the load and driving conditions) is the primary cause of excessive heat buildup. While 57/80 might seem correct, it could be insufficient for the van’s actual weight distribution and the specific driving demands. The fact that reducing the pressures seemed to improve the drive only slightly suggests the pressures were still too low for the driving conditions and van’s load.
    • Recommendation: A proper four-corner weight measurement (weighing each corner of the van separately) is crucial to determine the ideal tire pressure. Use this information in conjunction with a tire load inflation chart, provided by the tire manufacturer (Michelin in this case) for the specified tire size. It is important to note that the tire inflation pressures on the door sticker are for the OEM tires, not necessarily an after market tire.
  3. Tire Manufacturing Variation and Break-In:
    • The Possibility: New tires can exhibit slight variations in manufacturing quality. It’s also possible that the tires need a “break-in” period of a few hundred miles to allow the mold release agents to wear off and the tire to fully settle.
    • Why it’s Less Likely: While tire manufacturing defects are possible, they are relatively rare with reputable brands like Michelin. The break-in period is usually subtle and unlikely to cause such a dramatic change in handling.
    • Actionable Step: Visually inspect the tires for any obvious defects, such as bulges, uneven wear, or sidewall deformities.
  4. Alignment Issues:
    • The Potential: While less probable since the problem started immediately after the tire change, a slight misalignment could exacerbate the new tires’ handling characteristics.
    • Why it Matters: If the alignment was marginal before, the different tires might be highlighting the issue. Toe, camber, or caster problems can cause instability and contribute to sway.
    • The Test: A professional alignment check is recommended as a precautionary measure.
  5. Suspension Components:
    • The Long Shot: Worn shocks, struts, or other suspension components could also contribute to the problem, especially given the vehicle’s age and mileage.
    • Why it’s Unlikely (Initially): It’s less likely because the problem appeared immediately after the tire change. However, it’s worth considering if the new tires are simply revealing an underlying issue that was previously masked by the old tires.
    • Inspection: A thorough inspection of the suspension components is warranted if the other causes are ruled out.
  6. Rim Width Compatibility:
    • The Edge Case: Although unlikely given the tires are the same size as OEM tires, the rim width must be verified to ensure the tire is not mounted on a wheel too narrow or too wide. If the rim width is incorrect, the tires will not perform as intended and may experience abnormal wear or handling.
How Much Sway and Handling is Normal?
This is subjective. However, a well-maintained Ford Transit, even a high-top extended version, should track reasonably straight at highway speeds without requiring constant steering corrections. Some sensitivity to wind is expected, but the described “foot or more” of side-to-side movement is excessive.
What Can Be Done to Reduce or Eliminate the Problem?
  1. Re-Evaluate Tire Pressure with Accurate Weight Data:
    • Action: Get the van weighed at each corner and consult the Michelin Agilis Crossclimate DT tire load inflation chart for the correct pressure. Pay close attention to the maximum load rating for the specific tire size and load range, ensuring it exceeds the heaviest axle weight.
  2. Contact Michelin Directly:
    • Action: Explain the problem in detail and provide them with the vehicle information, tire specifications, and observed symptoms. Inquire if they have any specific recommendations for tire pressure or other adjustments for this particular vehicle and tire combination. They may have technical bulletins or insights not readily available elsewhere.
  3. Professional Alignment Check:
    • Action: Take the van to a reputable alignment shop experienced with commercial vehicles. Ensure they check and adjust all relevant alignment angles (toe, camber, caster).
  4. Consider Aftermarket Suspension Upgrades:
    • Options: If the problem persists, explore aftermarket suspension upgrades designed to improve stability and reduce sway. Options might include:
      • Rear Sway Bar: Improves roll stiffness and reduces body lean.
      • Upgraded Shocks: High-performance shocks can provide better damping and control. Brands like Bilstein or Fox are often popular choices.
      • Leaf Spring Upgrades: Stiffer leaf springs can increase load capacity and reduce rear-end sag, contributing to better stability. However, stiffer springs may negatively affect ride quality.
  5. Evaluate Alternative Tire Options:
    • Research: If all else fails, consider switching to a different tire model with a stiffer sidewall and a tread pattern optimized for dry pavement handling. Read reviews and consult with tire specialists to identify suitable alternatives. Look for tires specifically designed for light trucks and vans that prioritize stability and load-carrying capacity.
Should You Take Them In for Inspection or Replacement?
  • Definitely take them in for inspection. At the very least, a reputable tire shop can verify the tires are properly mounted, balanced, and inflated. They can also visually inspect for any obvious defects.
  • Replacement: Don’t immediately demand a replacement. Give Michelin a chance to offer a solution. If, after exhausting all other options, the tires still exhibit unacceptable handling, then explore the possibility of a replacement with a different tire model. Some tire retailers offer a satisfaction guarantee that allows for tire returns within a certain timeframe.
The Bottom Line:
The change in handling is most likely due to the construction and design of the new tires. However, don’t overlook the importance of correct tire pressure and alignment. Start by accurately determining the optimal tire pressure based on actual weight data and consulting with Michelin. If the problem persists, consider more advanced solutions like suspension upgrades or alternative tire options.
#vanlife #fordtransit tires #automotive #suspension
#vanlifeproblems #fordtransithandling #tiresway
#autoadvice #vanlifetips #mechanic
yakyak:{“make”: “gemini”, “model”: “gemini-2.0-flash”}
To contact Michelin about issues with your new tires, you can use the following methods:
  • Phone: Call Michelin’s Consumer Care at 1-866-866-6605, available Monday through Friday, 8:00 AM to 8:00 PM EST. For the Tire Concierge service, which can assist with tire-related questions, call 1-888-633-3339.
  • Email: Reach out to Michelin Customer Care at [email protected].
  • Online Contact Form: Visit www.michelinman.com, navigate to the “Contact Us” section, and fill out the form with details about your vehicle, tires, and issue. Responses typically take 2-3 business days.
  • Mail: Send correspondence to Michelin North America, Inc., Consumer Care Department, P.O. Box 19001, Greenville, SC 29602-9001.
Since you’re experiencing problems with new tires, you may also want to review the Michelin Promise Plan, which includes a 60-Day Satisfaction Guarantee and limited warranties for treadwear or defects. Contacting an authorized Michelin dealer can also help with warranty claims or inspections.
For faster resolution, describe your issue (e.g., specific tire problem, purchase date, or dealer) when contacting them, and consider calling during less busy times, like Tuesday or Wednesday, to minimize hold times.
