Five key points:
- Win before you fight
The best victory comes from planning, positioning, and strategy before conflict starts.Be well supplied, plenty of traps, use timing to your advantage, understand the battlefield.
- Know yourself and your opponent
If you understand your strengths, weaknesses, and the other side’s, you make better decisions.If I am in a hurry, I will not use the best technique. When I slow down and learn from each battle, things go better. For the mouse, it seems every battle is the first battle.
- Avoid unnecessary battles
The smartest leader does not fight just to prove strength. Winning without fighting is ideal.The mouse is quick, and great in tight spaces. Don’t try to defeat this enemy with speed and in tight places. Wait until you are at the advantage of open space, and when speed is not required. The little buggers have to eat constantly, and will come to you.
- Use deception and surprise
Make the opponent unsure of your real plans. Appear weak when strong, distant when near, and so on.Don’t set your traps in plain sight. The mice have been emerging from under the front seats. I place a cooler against the seats, set my trap behind, remove the cooler and step out.
- Adapt to conditions
Do not follow a fixed plan blindly. Adjust based on terrain, timing, morale, resources, and what the opponent does.From extensive use, my traps were developing a hair-trigger. After talking with a few Generals (locals) I was able to procure duplicates. I’ve also deployed a peppermint based spray near any of the entry points, and I will only do this when it is dry and conditions are proper.
In plain terms: prepare well, understand people (and mice), pick your battles, stay flexible, and don’t waste energy proving a point.
A few more pointers
- The traps they sell at Ace Hardware cost three times as much as the same ones you can buy at the discount stores.
- Peppermint extract can be found in the baking isle. Two tablespoons in a cup of water with a splash of vinegar. A 1oz bottle has 6 tablespoons and will go a long way, and cost about $3.50. I used an empty glass cleaner bottle.
As much as I would like to put the dead on pikes in front of my campsite, they would be way in the air and would not have the desired effect on the enemy on the ground.
