Nilight Schematic
I’ve got this set of 12 volt switches, with each switch emitting a blue LED light. I’d like to disable the LED lights. Can you look up the schematic, and tell me which wire I need to disconnect?
The purpose is twofold, one eliminate all unnecessary electrical consumption to extend battery life, and two, present a stealthy look for boondocking, no sign of Life.
This disables the lower light, the upper light comes on when the switch is engaged
Disconnect the wire to pin #6 (Lower Light Pos. / +) on each switch. This is the standard way to disable (or stop the constant illumination of) the lower blue LED on Nilight 5-pin rocker switches like the ones in your panel.
These are typical Nilight 5-pin illuminated rocker switches (common in their multi-gang panels). The pins, viewed from the back with the switch oriented upright, are generally:
  • #8: Upper Light Neg. (−)
  • #7: Lower Light Neg. (−)
  • #2: Incoming power (+)
  • #6: Lower Light Pos. (+)
  • #3: Outgoing to accessory/relay/load
The switches have two LEDs: a lower “dash/locator” light and an upper indicator that lights when the switch is on. In the factory/pre-wired panel setup, jumper wires typically feed power to the lower LED via pin #6 (often jumped from the main power on #2) and provide grounds on #7/#8.
How to do it
  1. Disconnect power to the panel first (for safety).
  2. Access the back of the panel/switches. The pre-wired connectors use clips—press the clip and gently pull the terminal off the pin (do not yank the wire).
  3. Locate and remove the wire/terminal on pin #6 of each switch you want to modify.
    • This stops power to the lower LED. Official Nilight wiring notes and manuals explicitly describe disconnecting #6 so the lower light only comes on with the switch (or stays off depending on the rest of the circuit), rather than staying constantly illuminated when the panel has power.
  4. Optionally, for a more complete disable of both LEDs:
    • Also disconnect the ground wires from pins #7 and/or #8.
    • Or leave the grounds and just remove the positive feed(s).
  5. Insulate any loose terminals with electrical tape or heat-shrink so they cannot short.
  6. Reassemble and test. The switches will still control their loads normally; only the indicator LEDs will be affected.
Notes / caveats
  • Exact behavior can vary slightly by panel model and whether the panel uses constant battery power vs. ignition/accessory power, but #6 is the consistent pin called out across Nilight guides for controlling the lower light.
  • The upper LED is usually tied to the switch output/state, so removing #6 primarily targets the always-on/locator light. Fully killing both may require also isolating the grounds or the internal LED circuits.
  • If your particular switches have slightly different labeling or an extra pin, double-check the numbers molded on the switch body or the included diagram.
  • These are low-current LED circuits, so removing the wire is safe and reversible.
If the lights behave differently after removing #6 (or if you can share a clear photo of the back of one switch showing the pins/wires), I can refine the advice further. Always work with the power off and use proper fusing on the main panel feed.
